6 members (GrumpyPa, Jon G4LJW, Plus Four Guy, IcePack, DJC, James B W), 276 guests, and 19 robots.
+8Rich 95
John V6 52
Posts838,002
rockabilly john
#103729 08/09/12 09:23 PM
sawman Offline OP
Well, I now have my new (ex cerealsurfer) tubular manifold and sporty exhaust fitted and it sounds fab, but I notice that the (wrapped) down pipes are quite close to the starter motor.
Should I be thinking about some form of heat shield between, there is maybe an inch gap between the body of the stater and the pipes, and a little less between the wire that runs along the top of the starter.
any thoughts, or suggestions welcome....
Take a look at www.agriemach.co.uk they stock all sorts of heat sheilding material.
Gerry.
Gerry
I once fried my alternator on a 1981 4/4 on a track day event. If you have the starter too close to the exhaust manifold, it might be a good idea to install a heat shield.
Harald
Harald
If you wade through the peripherals, this post was about insulating various bits & pieces.
The starter motor doesn't need anything fancy, a simple wrap works, although you could make an aluminium shield and line it with foil.
http://www.talkmorgan.com/ubbthreads.php/topics/38329/3
sawman Offline OP
Thanks for the link Dave, I remember reading that thread, but I couldn't find it via the search thingy
cheers
simon
Glad to hear you have managed ok to get it fitted. It does sound quite cheeky for such a modest looking piece of kit.
The starter should survive ok, but a heat shield would probably help. The exhaust wrap is amaisingly effective!!!
sawman Offline OP
Cheers Andrew it does sound quite fruity, I have to go through the tyne tunnel tomorrow (twice), what a shame! listening
