Topics49,905
Posts838,096
Most Online1,063Jun 14th, 2026
C´mon
- always remember: "you´ll never walk alone"...
Shared misfortune is half misfortune - as a german saying tells us
It doesn´t matter how fast it becomes, but how it becomes fast.
2015 Roadster 3.7
Why do you think I keep posting?
I found the problem. 15 amp fuse feeding headlights & indicators ( possibly others as well). 2 x 60w headlight bulbs=10 amps. I haven't had chance to check the spots, but assume the same wattage & we have 20 amps of lamp load alone
I'm going to disconnect the spots for the moment & later on add a relay & a feed from a separate fuse. There are un-used fuse ways, so I should be able to use one of those.
Ian
3.7 Roadster 4" Ruston Procter SD Tractor 1905 Merryweather steam fire engine
Another useful catch for me.... Thanks.
+8 4.8
Any time
This was a problem created by my dealer when he fitted the spots. Without spots, no problems.
Have you been to see yours yet, Neil?
Ian
I used to have twin spots on my Honda F1 400/4. Flashing them knocked 5 mph of the speed!! They had a relay fitted
Any time
Ian
I have pinged a note to the incredibly helpful BHM to alert them to the fuse/relay issue on the spots, so hopefully they can attend to that.
I haven't been to see mine, build started last week and I'm a bit unsure of when/how I should go see it. When it's in the trim shop is the consensus.
+8 4.8
I'd agree with that. Your dealer should be able to tell you when it's there, or a call to the factory will give you a date.
Ian
Your dealer fitted spots without an extra relay, or additional fuse?
They want shooting!
Graham (G4FUJ) Sold L44FOR 4/4 Giallo Fly '11 MINI Countryman Cooper D All4 '90 LR 90 SW
They want shooting!
Quite!
I got around to changing the rear number plate mounting. At least it doesn't flap in the wind now
Ian
