5 members (andymog1, IcePack, ChrisConvertible, TalkMorgan, mph), 231 guests, and 28 robots.
+8Rich 99
John V6 55
Topics49,908
Posts838,116
Page 5 of 12 1 2 3 4 5 6 7 11 12
C´mon somestick - always remember: "you´ll never walk alone"... wine
Shared misfortune is half misfortune - as a german saying tells us grin2 cheers
drive 2015 Roadster 3.7
Why do you think I keep posting? laugh2
I found the problem. 15 amp fuse feeding headlights & indicators ( possibly others as well). 2 x 60w headlight bulbs=10 amps. I haven't had chance to check the spots, but assume the same wattage & we have 20 amps of lamp load alone nono
I'm going to disconnect the spots for the moment & later on add a relay & a feed from a separate fuse. There are un-used fuse ways, so I should be able to use one of those.
Ian
3.7 Roadster
4" Ruston Procter SD Tractor
1905 Merryweather steam fire engine
Another useful catch for me.... Thanks.
+8 4.8
Any time cheers
This was a problem created by my dealer when he fitted the spots. Without spots, no problems.
Have you been to see yours yet, Neil?
Ian
3.7 Roadster
I used to have twin spots on my Honda F1 400/4.
Flashing them knocked 5 mph of the speed!!
They had a relay fitted
Any time cheers
Ian
I have pinged a note to the incredibly helpful BHM to alert them to the fuse/relay issue on the spots, so hopefully they can attend to that.
I haven't been to see mine, build started last week and I'm a bit unsure of when/how I should go see it. When it's in the trim shop is the consensus.
+8 4.8
I'd agree with that. Your dealer should be able to tell you when it's there, or a call to the factory will give you a date.
Ian
3.7 Roadster
Your dealer fitted spots without an extra relay, or additional fuse?
They want shooting! exting
Quite!
3.7 Roadster
I got around to changing the rear number plate mounting. At least it doesn't flap in the wind now laugh
Ian
3.7 Roadster
