2 members (IcePack, RichardV6), 450 guests, and 43 robots.
+8Rich 90
Topics49,841
Posts837,322
NeilM #104372 15/09/12 06:12 PM
Rest assured NeilM that whenever there is no rain the Morgan will be out on the road (so that'll be 10 minutes then!)but he needs to be tucked up in the meantime.;-)
Stuart
Rich Maroon and Royal Ivory (ish) +4
scratched #104376 15/09/12 06:46 PM
A jet wash is a bit fierce, a gentle hosing shoud be suffice. Run some 3 in 1 oil or similar aIong the piping between sills/wheel arches and body work every 3 months or so. I grease the king pins with Castrol CL grease every 400 - 600 miles, 4 or 5 strokes of the grease gun and wipe off any surplus, whilst the car is jacked up I check the front tyres for damage and touch up any flakey underseal with some black gloop containg waxoyl.
scratched #104381 15/09/12 07:47 PM
Hi Scratched, definitely grease up before hibernation.
I grease the front suspension at least once a month, effectively ever 300-500 miles.
In the first year I have gone through about 3/4 of a tub.
Ian
Easter #104385 15/09/12 09:12 PM
South Wales Correspondent
If you have the patience and time to get all the Waxoyl off, I'd go with Tectyl. Much better job
This was a Dave W tip which, eventually, I took on board and I've never regretted it
GLLHG
NeilM #104437 16/09/12 07:44 PM
I recently under sealed my 4/4 using Biltong Humber aerosol. Easy to do after masking up. Dries to a nice consistency and look. Just in time for winter runs!
sospan #104471 17/09/12 08:38 AM
That's BILT HUMBER !
That Penderyn malt is good stuff.
I treated myself last night.
sospan #104480 17/09/12 10:29 AM
Thanks sospan. I wondered why google came up with nothing!
Hope your head is ok today, malt always makes mine throb but maybe that is just the Scottish type. I am ashamed to say that I had never heard of a Welsh one.
And thanks for the tip.
Stuart
sospan #104534 17/09/12 06:40 PM
Wondered why you were spraying dried meat under your car - now I understand laugh2
Graham, G4FUJ #104575 18/09/12 06:52 AM
Gone to Porsche
Gone to Porsche
Maybe interesting to show you the difference in the 2 products
Underbody Underseal Protection
Description
Underbody Protection Gun is a ready-to-use bitumen based waterproof coating which can be applyed by a airless gun or a airpressured gun. It is used to form a protective layer against rust and mechanical abrasion.
Characteristics
Creates a tough-elastic layer with excellent protection against rust, oils, salt and abrasion.
Sound deadening.
Resistant to water and solvents.
Applications
Protection of wheel arches and car underbodies against corrosion.
Sound deadener.
Directions for use
Application Method :
- Clean, dry and degrease substrates
- Protect substrates which are not going to be treated
- Mix product thoroughly before application
- Apply with a airpressured or an airless gun
Application Temperature : +10°C until +25°C
Clean with : White Spirit
Repair with : Underbody Protection Gun
Anti-Gravel
Description
Anti Gravel provides a protective layer against rust, salt, sand and stones.
Characteristics
- When dry, provides a tough elastic film excellent resistance to gravel.
- Does not contain bitumen nor asphalt
- Can be painted or sprayed over.
- The dry layer is not affected by water nor solvents
Applications
Protects the sides and underside of cars against gravel and rust
Layer also helps counter noise and vibration, a.o. in the wheelarches.
Directions for use
Method: clean the underside of the car carefully, making sure it is dry and grease free. Cover areas not to be treated. Shake before use. Anti-gravel
can be applied with a brush or roller but best results are obtained with a pressure gun or air gun in undiluted form. (recommended pressure: ±4bar;
gunopening: 2-4mm)
Application temperature: +10°C to +25°C
Cleaning: Acetone or any other solvent
Repair with: Anti Gravel
Dean-Royal #104874 20/09/12 04:50 PM
Bilt Humber do kits to suit cars, including rust convertor, cavity wax and bungs to plug holes, undersell wax. Also other products. I find them good and easy to use as they do aerosol versions for use if you don't have a compressor. I have gone this route as its convenient to buy aerosols for the small amount needed for a Morgan.
