7 members (RedThree, Davetherave, Grumpy2, Craig Jezz, Aeromax51, Socalm3w, Gambalunga), 254 guests, and 28 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,145
Page 1 of 5 1 2 3 4 5
#106198 30/09/12 07:10 AM
Bad news, chaps. A new fungus which kills ash trees, has reached the UK scared Apparently, it does to ash trees what dutch elm disease did to, well, elms. I hear it's killed 90% of the ash trees in Denmark in 7 years. Could the ash frame go the same way as the elm chair seat? frown2
Ian
3.7 Roadster
4" Ruston Procter SD Tractor
1905 Merryweather steam fire engine
shiremog #106201 30/09/12 07:18 AM
That's disturbing...
Graham, G4FUJ #106202 30/09/12 07:35 AM
In Australia (WA especially) quarantine regulations are very strict. I thought over the top until I moved here. Then you learn parts of Aus have diseases that others (mostly WA) do not and that they want to keep it that way.
When we moved here they went through our posessions very careully - they found some sprayed pine cones (part of our Christmas decorations) - they had to be "cleaned" (for a fee).
Perhaps the UK being an island needs to take a similar stance (as with Rabies)?
Just a thought!
R.
Richard - Aus #106204 30/09/12 07:54 AM
http://www.telegraph.co.uk/earth/earthne...land-Trust.html
Do I remember correctly that Morgan imports most of its wood from Belgium? In that case an import ban could be a problem.
1972 4/4 2 Seater
Richard - Aus #106205 30/09/12 07:57 AM
It is now classed as a quarantine pest so movement is controlled, but apparently it's already been found as far north as Glasgow, although so far it's only been found in planted trees, not the wild stock.
Trouble is, I believe the ash used by the factory is all imported.
3.7 Roadster
tmg513 #106206 30/09/12 08:09 AM
According to the factory most of the timber is sourced from Norfolk. It would be a disaster for ash trees to be killed off after all the elms.
As far as import bans are concerned, by the time the government endlessly talked about the human rights of overseas growers etc, the disease could well end here.
shiremog #106233 30/09/12 11:55 AM
South Wales Correspondent
Ian
I seem to have vague memory that in the distant past, MMC used ash from Belgium and regulalrly used to find bits of shrapnel, barbed wire etc in it.
Anyone confirm this?
Regrds
GLLHG
GLLHG #106239 30/09/12 02:12 PM
Yes spot on G it's in the Gregory Huston Bowden "First & Last" book.
I'm pretty sure that I have read recently somewhere that the ash is now UK sourced, so not good news at all.
Regards
+8Rich #106244 30/09/12 02:38 PM
Regards
Thanks- senior moment there! I should have known 'cos I've got the book! ( Birthday present in 1972 and then got the second edition in the eighties!!) In fact ( and purely because wet sundays in Wales aren't the most exciting when you're Hopalong Cassidy- I did a bit of OCD- ing and found it in there. I still can't belive that he went for the scheme on tha PLus 8 if his. The Yellow- at a push ( and becuase I lknow mr Lomax has a huge soft spot for yellow cars- but the upholstery-??
No Ta
Cheers
GLLHG
GLLHG #106453 01/10/12 05:20 PM
Here in Michigan we have a pest known as the emerald ash borers, that have led to a failing campaign to try and keep them at bay. As of now there are 2 almost dead ash trees right outside my office window. These bugs have had a similarly deadly result for a high percentage of our ash trees state wide.
Charlie, Former Editor
