4 members (Lordofthewings, Brian Dearle, jim109b, Bob_Price), 277 guests, and 73 robots.
John V6 68
+8Rich 66
DaveW 64
9,208 Registered Users
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,346
Posts813,060
Captain Morgan, IRWIN
le Asbo du Bling
le Asbo du Bling
Small slot behind the aero screen seems to work, but I've also left them on the seat.
Slowly going green
Has anyone tried fitting a child seat? I assume its feasible with the seat belt, but it might sit a bit high compared to the "door"? Hoping to use mine for the school run this summer smile
le Asbo du Bling
le Asbo du Bling
Depends on the type, if it a booster cushion you might struggle given the limited width at the seat base, you'll also struggle to get to the seat belt clip.
You might be able to get away without a seat but depends on the size of your youngster.
Slowly going green
Unfortunately it will be the full on, biggest you can get size, not even just a booster. Sounds like I might struggle then. Could have a disappointed 3 yr old (4 by the time the car arrives) on my hands
MikeMTW Offline OP
Originally Posted By 1560
go easy on running the engine in
when you fill it up "full full full" it starts more difficultly but it does, give it some throttle and get off with a burn out
then you won't stall
rear tire: lying down on the floor and look for the valve
(never done that, only check the fronts)
have now 4500km including a trip from Brusselas to Modena
without getting in to troubles other than a loose cable at the battery
but it is good to dismantle it and look how things are mounted
as when you need to, you'll know how to
My next question is....
.. How long is a piece of string?
What sort of range are you getting from a full tank on along trip, and the samne question if your doing lots of sort trips. I'm try to guess the sort range I can expect.
From what I've been told so far I reckon I should get between 100miles (short runs) to 200miles (long) on a tank. But would like to hear some real life figures. Everyone driving style is different. But I will be running the car in you will take it easy.
Someonme mentioned Brooklands on Sunday, its about 80 miles of A-roads (I'll avoid motorways) from here, and if the forcast looks promising and I can 'ditch' a prior engagement I may venture out.
If I do go, I will take a can of petrol with me (assuming it will fit!) smile
I seem to remember that when I ran it dry recently, it was showing at about 230 miles of generaly mixed driving, which was a disappointing 28 - 29 mpg, given that I am still running it in at 900 miles.
Does make me wonder what the drag coefficient is on this vehicle. The engine is a torque monster and not one made to get maximum fuel economy. Still, 28 does seem quite low, but maybe its what real world MPG is going to look like. Have other recorded their MPG?
My "old" Saab had a plasitc clip on the dash to hold the ticket down.
Goodwood Drifter
Goodwood Drifter
200miles on eco-driving (like motorways)
but I refuel at 150miles
Steven
now: +fourLM62
MikeMTW Offline OP
I was told to expect about 28 mpg! So at least I know this is a realistic figure. Filling up at around 150 miles sounds like sound advice.
