5 members (mph, Robbie, Dougie, BLUE+4, JohnHarris), 225 guests, and 62 robots.
+8Rich 78
Topics49,871
Posts837,677
Rudolf
Page 3 of 3 1 2 3
Reading about the splits on a few early tanks, and not liking the looping top entry hose, as well as finding my original oil hoses were rock hard and prone to weeping even with fully tightened clamps, I decided a new tank and hoses were in order. I drew up and commissioned a .125" wall tank from the talented crew at Twisted Choppers in South Dakota. Had them build it per bike practice with return and vent hoses entering the tank bottom, with 'stand pipes' going up to near the tank top. The tank is an inch wider to regain capacity lost to the increased wall thickness. New Aeroquip hoses designed for hot oil and AN fittings make for a neater installation IMHO. Also added a drain in the feed line (stainless gauge port for 1/2" line).
Late 2012 M3W
If you don't mind me asking, what did this tank cost you?
Lance
1981 Plus 8
2016 Three Wheeler
2022 Corvette Stingray Convertible z51
If I recall correctly the alloy fabrication and welding was a couple hundred. I sent them the alloy materials including cap and threaded fitting bungs. A local welder did the stainless tubes to the stainless pipe thread/AN adaptor welding. (3/8 NPT male to AN-8 male). Then there was AN hardware and new hose, plus the powder coating... so somewhere around $500 all in for the conversion.
There are weld it yourself 6" diameter alloy tank kits sold on ebay with thin walls and no fittings for about a hundred, btw.
Late 2012 M3W
Very good job
Page 3 of 3 1 2 3
