4 members (BertL, Saxonian, Mybluemog, Alan Patterson), 246 guests, and 122 robots.
+8Rich 77
Topics49,870
Posts837,668
Rudolf
Easter #109779 29/10/12 10:40 AM
Do you mean pushing down on the wing i.e suspension or somehow pushing the actual wheel?
nick w #109793 29/10/12 01:42 PM
Originally Posted By nick w
I certainly never leave the handbrake on when in the garage - I've had many cars over the years that do what you've described; gave up handbrake use where not necessary a long time ago. I just leave the car in gear.
nick
Same here...
...and will also add that it is best to make sure that the brakes are dry before you parking up for a few days or more...so, don't wash the car and wheel it into the garage with water on the discs.
Jaguar F-Type V6s roadster
2009 Harley Davidson XR1200
1986 Honda VFR750F (RC24)
It's worth adding that should you ever take your Morgan on a track day..... Never use the handbrake in the pits when the discs are red hot. Can cause all sorts of problems....
As above, I never use the hand brake in the garage. All cars will find that the pads stick to the discs after a few days. Quite normal. Just leave the brake off. smile
+8 4.8
I usually lean on the top (just past top dead centre) of the o/s front tyre with the palm of my hand, give it a shove forwards and twang! Job done
