Topics49,871
Posts837,679
Posts: 41 |
Do you mean pushing down on the wing i.e suspension or somehow pushing the actual wheel?
Posts: 1,647 |
I certainly never leave the handbrake on when in the garage - I've had many cars over the years that do what you've described; gave up handbrake use where not necessary a long time ago. I just leave the car in gear. nick Same here... ...and will also add that it is best to make sure that the brakes are dry before you parking up for a few days or more...so, don't wash the car and wheel it into the garage with water on the discs.
Jaguar F-Type V6s roadster 2009 Harley Davidson XR1200 1986 Honda VFR750F (RC24)
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
It's worth adding that should you ever take your Morgan on a track day..... Never use the handbrake in the pits when the discs are red hot. Can cause all sorts of problems.... As above, I never use the hand brake in the garage. All cars will find that the pads stick to the discs after a few days. Quite normal. Just leave the brake off.
+8 4.8
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
Do you mean pushing down on the wing i.e suspension or somehow pushing the actual wheel? I usually lean on the top (just past top dead centre) of the o/s front tyre with the palm of my hand, give it a shove forwards and twang! Job done
