12 members (John V6, IcePack, JohnHarris, Chris Cosher, GrumpyPa, +8Rich, Graham, G4FUJ, MartinB60, RichardV6, High Hamster, Morganmike, TalkMorgan),
299
35
Topics49,904
Posts838,092
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
How strange. The floor mats in our Plus 4 are secured by press studs in the rear corners. I had assumed that was standard practice.
Posts: 14,009 |
Mine are too Peter. I modified a new carpet mat on the passenger side with an alloy footrest....for my rather short legged passenger. She complained of sliding forward when I braked hard! The press studs pulled out too easily when she pressed her feet hard on the footrest, so I used the lift a dots.
You might ask why I didn't screw the footrest down to the floor; I wanted to be able to get both mats and rest out easily and didn't want to cut the mat.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Thanks for the effort in the right up. Car looks great and welcome!
Richard 1976 4/4 4 Seater
Posts: 181 |
In answer to some of the questions : The Simmonds steering wheel is cosmetically nicer than the original it is very slightly smaller and does give a much improved view of the rev counter & fuel gauge. Front inner tubes: have an offset nickel plated valve , superior Blockley inner tube, so they are heavier than a motorcycle tube. If you are touring I would suggest for the sake of a few pounds you carry a spare, you are not going to find a substitute easily. Tool Box: I am located in Northampton the traditional home of the boot & shoe industry so it was nice to find a local person to make the box. It was dyed to match the interior colour and is lined in black goats skin. Obviously you could choose a colour to suit your car. I should make it clear that the box is bolted to the car. Her details are http://www.facebook.com/LeatherandLinen & Aysha Warrak <awarrak@hotmail.com> Thanks for all your positive comments.
Posts: 181 |
Should have said photos are on flickr link.
Posts: 508 Likes: 1
Dreiradschubser Talk Morgan Regular
Posts: 508 Likes: 1 |
Good morning John, I like your write up and congratulations for your car, I have to wait some more months  Could you post a picture of this: Flap fitted tho help protect the seat belt mechanism from the wet & dirt, without this you finish up with very dirty clothing. Greetings from germany Achim
Posts: 3,841 Likes: 11
le Asbo du Bling Talk Morgan Addict
Posts: 3,841 Likes: 11 |
John I'm not sure what your chassis number is but as before I'm guessing its an early car.
Waldemar the factory have a fix for the problem so the seat belt box now has a plate on the underside to prevent this problem. So if your car is still to be built you shouldn't have this issue.
Slowly going green
Posts: 191 |
Two inner tubes ordered! Many thanks, I told them to expect a few calls as you had posted the link on this forum!
Posts: 477 |
I too needed to provide a footrest on the passenger side and made an angled footrest with a bit of plywood and some battens, I glued on a matching piece from a spare car mat and it pushes into the footwell and effectively shortens it. It provides useful hidden storage behind it and the average non-Mog person wouldn't know it was any different. It wedges in tight with battens to brace it against the original end of the footwell and I keep a few very useful things behind there, all out of view.
Dave
Posts: 14,009 |
I used one of these for the passenger footrest. footrest Screwed down through a spare floor mat to an ply base below and as said earlier, the mat secured with lift a dot fasteners. Great for storing things such as a first aid kit, spare bulbs etc under it.
