6 members (MartO, BobtheTrain, gomog, JohnHarris, Moggo, Grumpy2), 418 guests, and 71 robots.
Topics49,848
Posts837,406
DazMog, The Impaler, tlchzj79
#110834 08/11/12 06:03 PM
I went to start the Roadster yesterday & the battery was flat. It had only been standing about 4 days (OK,OK I know I should use it more! hide ). I never had this problem with the mk1 Roadster. It seems to be charging OK (14.5 volts at tick-over with headlights & screen heater on) so it's either an iffy battery or one hell of a drain while it's not running. As it's the same basic set-up as the Mustang, I somehow can't see Mustang customers putting up with that. Has anyone else with a 3.7 Roadster left it for a similar time?
Ian
3.7 Roadster
4" Ruston Procter SD Tractor
1905 Merryweather steam fire engine
shiremog #110835 08/11/12 06:06 PM
Maybe it wasn't fully charged from new. I use a conditioner all the time................
Or maybe its faulty, therefore a warranty job?
DaveW #110844 08/11/12 08:11 PM
Sounds like a duff cell - get it load-tested by a friendly garage or similar...
2011 +4 'LB' Indigo Blue, Heron trim
Saab 9-3 1.8T Sportwagon
Mine's been fine Ian....
There's no drain on the battery is there? Unless you have a tracker.
You'll have warranty on that battery won't you? I never trust a battery once it's been completely discharged.
+8 4.8
Neilda #110872 09/11/12 07:52 AM
There is always a small drain on a road car, the alternator takes a small amount and any alarm system like wise.
However, it should not be an issue as both should be small drains and the car should start normally after being left for at least a fortnight.
I'd check with a dealer to make sure there is no proceedure to be done when changing a battery, and then without turning anything on, put my meter in the path and measure the current drawn when the car is turned off.
Thanks for the comments, everyone. I have fully charged the battery, I've also been on some longish runs, so it should be fully charged. The only drain I'm aware of is the immobilizer. I'll put an ammeter on it when I get chance. Could be a duff cell but it's only a few months old.
What's the longest anyone's left their 3.7 Roadster without any charger/conditioner on?
Ian
3.7 Roadster
shiremog #110965 09/11/12 05:31 PM
I'm only up to 3 days. My garage is trickle city because of other cars....
But my Range Rover has been left for 3 weeks (holidays) without a problem.
Not sure that helps, but tight I'd mention it! smile
+8 4.8
Neilda #110966 09/11/12 05:34 PM
Iv'e left my 2009 Sport for 3weeks (holiday) and all was well.
+8Rich #110989 09/11/12 07:55 PM
Q
Q
Ian,
I left my 3.7 Roadster for 2 weeks in the garage and had no problems to start it.
But a month ago I had problems with the electrical system, too. After having started the car the brake lamp was illuminated (but the park break was not applied), the signal lamps and flash lights didn't work. I opened the magic aluminum box on the right-hand side and pressed all these small black boxes into their sockets (because some were not really fixed) and now everything was o.k. and worked without problems. After this exercise I am not sure how reliable the electrical system is.
Regards,
Axel.
Quicksand #110993 09/11/12 08:29 PM
Thanks, Axel. It seems that there is a problem with my car then. I'll have to investigate further...
I suspect that the relays on your car ( that's the small black boxes) weren't properly fitted, or possibly knocked partly out. I've not heard of relays coming loose during normal use, so hopefully, it won't happen again.
Ian
3.7 Roadster
