0 members (),
336
Posts837,277
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
Check the water pump. I once had a failing water pump on an MGB, and there was a significant vibration through the driveline. Also check the dynamo/alternator bearings.
Posts: 198 |
Recently I noticed that the clamp that secures the joint between the manifold and the catalytic converter was loose. I tightened it up and immediately noticed a vibration through the clutch on changing up. The vibration continued in top gear at 3k rpm I eased the clamp - and the vibration disappeared. Just a thought for you. All the best Tony
Posts: 167 |
Because it happens at a specific RPM range, one is inclined to suspect the engine balance. Mine has a worn pilot bearing in the flywheel that allows the clutch to get off-center. If that happens I disengage the clutch once or twice to allow it to re-center. It usually shows up in top gear on the freeway. Pita. will pull the engine one of these days and replace the bushing!
'65 +4 four seater
