4 members (Mac39, Zach, Mogdavid, B&C Morgan), 389 guests, and 45 robots.
+8Rich 81
Topics49,859
Posts837,500
Jonny72
#118751 08/01/13 08:31 PM
JMP Offline OP
Has anyone had a problem with the horn ring on their mog? I have a problem with the horn sounding with the turning of the steering wheel at times.
On investigation I have found one plastic ring that presumably goes around or inside the metal horn ring broken into two parts. It's now glued back together but not sure how it should be assembled.
Question:
The contact that slides on the ring is bent out of shape and a pic of the assembled unit would be useful. Does anyone have a pic or able to suggest a source of how the horn ring should be fitted. A google search hasn't provided anything yet.
Thanks
JMP #118785 09/01/13 08:07 AM
Sorry I can't help you, but interestingly I have the same problem with the contact that slides on the ring, it's bent out of shape. I took it out and fixed it but now it's bent again and the horn doesn't work. Does anyone have a clue why this happens?
I'll get back to you if I can find a picture.
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
