3 members (Image, Luddite, Nickplus4), 395 guests, and 19 robots.
+8Rich 92
Posts837,284
Page 5 of 17 1 2 3 4 5 6 7 16 17
Lecat Offline OP
Peter: Wobble is not really a 'problem', hardly notieable - could actually be my wire spoked wheels that needs centering (if that's the correct expression...). I haven't had the time to check everything yet, but I will when I rebuild the front. thumbs
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
Lecat Offline OP
If you are interested in discussions about Rising Rate Suspension contra Double Wishbone Suspension, this is the topic:
http://www.talkmorgan.com/ubbthreads.php/topics/121833/Double_Wishbone_IFS_for_Classi # Post121833
I'm still eagerly awaiting the Rising Rate Suspension kit to become available drive
Kevin Vernon now has the Suplex rising rate conversion kit in stock, mine is being fitted next Friday
Hamwich,
Would really appreciate your considered opinion on this mod when you have done a few miles ( I suppose after the next weekend as I suspect you'll not be able to resist trying it out!!!)
cheers from a sunny Ireland -- had a great blast in the Mog this morning!!
Robbie
2021 Plus Four -- Helga
211-WX-1433
We might be able to run some back to back comparison tests on a Highlands tour in late June... smile
That's if I can keep up with that GM powerplant Tim has in his 4/4 grin2
PJB Offline
So how will you assess? Maybe - who has the worse back/neck pain after hundreds of miles on Scottish roads or who comes through fast bumpy corners still with a smile on their face. I don't remember many Morgans hanging on my tail in 2011 through the Highlands, and those were just the prototypes.........PJB ;-)
Lecat Offline OP
Thanks for info, Hamwich smile and good luck with yours.
PJB #130047 05/04/13 08:57 AM
You were too busy burning up 911's to notice whether any Mogs were keeping up Peter rofl
PJB Offline
Yea, I got him on the corners, the look on his face was a picture - but the slightly breathed on CVH was no match on the straights, good fun though - the 2.0 Zetec might have more chance.
Others might be interested in that the Zetec 2.0 litre can be installed in place of the 1.6 CVH using the following from the CVH:- gearbox, clutch, exhaust manifold & system, inlet manifold, Weber DFT 32/34, engine mounts, rad, alternator and other bits and bobs and still give over 100 bhp at the rear wheels with a calculated 138 bhp at the flywheel from the rolling road test. Brmmmmmmm! PJB.
PJB #131190 12/04/13 07:06 AM
I am interested in the rising rate front suspension conversion from Suplex. Has anyone fitted these springs and what is the result?
Titus
2007 Morgan +4 4seater
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
