9 members (Graham, G4FUJ, DCH, flyfisher, JMcL, Robbie, vincentvg, ScotiaSteve, Luddite, MATTMOG), 241 guests, and 46 robots.
+8Rich 76
Topics49,863
Posts837,553
#120735 26/01/13 03:52 PM
woodsy Offline OP
Hi,
The pilot lights mounted on top of the wing how do you change the bulbs? Are they a bayonet fitting? What I thought would be a five minute job is taking a lot longer.
Thanks
Andrew 2010 +4
2015 Lapis Blue Roadster
1972 British Racing Green MGB Roadster
woodsy #120739 26/01/13 04:31 PM
Yes.
However, if the base of the bulb has got damp it may have rusted into the holder - a not uncommon problem!
Good luck,
Hi. I used a bit OF waterhouse with a diameter that fits On top OF the bulp
Hi - it's a Lucas 1130 or possibly a copy/clone. The photos on this page show the bulbholder - looks like a bayonet
http://www.holden.co.uk/displayproduct.asp?pCode=010.303
nputtick #121320 31/01/13 08:45 AM
Ivo Offline
TM Photographer of 2011
The bulb is very "far in" , so you need very thin fingers, or as I did, a "special tool" .
I took some thin long flat nose pliers and wrapped some rubber band around them, to be able to "grab" the bulb and turn it. I broke the old one, and two new ones, before I had the right feeling.
Good luck thumbs
sunny
1998 +8 (permanently out of service frown )
Ivo #121326 31/01/13 09:04 AM
It's a BA9 5 or 4w bulb
9mm, symmetrical bayonet, one centre pin.
Maplin's base drawings
