1 members (rory kim),
304
56
Topics49,843
Posts837,339
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
Actually I don't mind at all  but they should ask before lifting a baby over the door to stand on the seat for a photo. Don't you think? Er...... WTF?! I cannot believe how some people treat the property of others. I was chatting to a car dealer recently who said that some of his cars had been damaged at Goodwood when people were posing 'on' the cars.... Sitting on bonnets etc. Grrrrrr! Sorry. Thread drift.
+8 4.8
Posts: 407 |
Mine doesn't have any leaks, but the left door doesn't work properly. It can only be opened from inside, and you have to lower the window first, as it doesn't automatically dip as it should. Other than that, it has been fun.
Gone to Porsche Part of the Furniture
Posts: 4,333 |
Mine doesn't have any leaks, but the left door doesn't work properly. It can only be opened from inside, and you have to lower the window first, as it doesn't automatically dip as it should. Other than that, it has been fun. There is a method for resetting the Windows !!
Posts: 407 |
Posts: 4,333 |
1 Cancel and Reset isolator switch under bonnet 2 Turn ignition to ON position but not to cranck position. 3 press both window switches to send windows down, 4 once down to limit, hold the switches and count 10 seconds, then send windows up, once they have reached the top limits, count 10 seconds again holding the switches open
5 test windows for normal action with doors closed. 6 if that fails try again
some times takes a couple of goe's to perfect it 7 ring Dealer
But it is what i was shown and it works for the Max.
Posts: 407 |
I know of the isolator switch, but how do I cancel and reset it?
Posts: 407 |
I did these things, but now neither window works. Maybe I'll leave it to the experts.
Posts: 87 |
Press the red switch, close the lever, then follow Dean's instruction.
Regards, S.C.
