2 members (JoeSpeetjens, Ian B),
321
74
Topics49,867
Posts837,614
Posts: 33 |
Hi,
The pilot lights mounted on top of the wing how do you change the bulbs? Are they a bayonet fitting? What I thought would be a five minute job is taking a lot longer.
Thanks
Andrew 2010 +4
2015 Lapis Blue Roadster 1972 British Racing Green MGB Roadster
Posts: 28,901 Likes: 352
Posts: 28,901 Likes: 352 |
Yes. However, if the base of the bulb has got damp it may have rusted into the holder - a not uncommon problem!
Good luck,
Posts: 27 |
Hi. I used a bit OF waterhouse with a diameter that fits On top OF the bulp
TM Photographer of 2011 Talk Morgan Regular
Posts: 963 |
The bulb is very "far in" , so you need very thin fingers, or as I did, a "special tool" . I took some thin long flat nose pliers and wrapped some rubber band around them, to be able to "grab" the bulb and turn it. I broke the old one, and two new ones, before I had the right feeling. Good luck
 1998 +8 (permanently out of service  )
Posts: 1,947 |
It's a BA9 5 or 4w bulb 9mm, symmetrical bayonet, one centre pin. Maplin's base drawings
