10 members (Jon G4LJW, bmgermany, MATTMOG, Hamwich, RedThree, Mogdavid, MJF, sewin, linklaw, nick w), 208 guests, and 34 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,041
Chaps,
Main / Full Beam / Horn failed this afternoon. Weird thing was that the full beam light stayed on for sometime (and couldn't be switched off) even after key out....
So, not just a fuse then... Where should I be pointing my mechanic..?
Thanks in advance.
1987 Morgan Plus 8
Thanks in advance.
Hi Paul,
Tell your mechanic that your horn/dim/dip stalk has failed. That is the one on the left of your steering wheel. You can get another from the Factory or any Morgan dealer.
Lorne
I had a similar problem which was sourced to the Dim/Dip module on the 4/4. Removed the module and problem went away. flag
Phil Egginton
1979 4/4 4 seater
Paul,
Phil could well be right. The same wires go through the dim/dip module too. Good thinking Phil!
Lorne
Get an early triumph stag one as they are the same and only £12 on ebay, rarther than £70 plus vat. You need one with a slight kink.
Happend to me to.. I take it is a 80s plus 8, so the same period of switch as 87 car.
Will
Yup, an 1987 Plus 8...
Thank you very much for your advice guys!
1987 Morgan Plus 8
