10 members (Arwyn Williams, John Wilcox, AlyMatt, Plus Four Guy, jbk, Sir Percival, TalkMorgan, JohnHarris, Saxman1964, gomog),
218
35
Topics49,901
Posts838,046
Posts: 94 |
Chaps,
Main / Full Beam / Horn failed this afternoon. Weird thing was that the full beam light stayed on for sometime (and couldn't be switched off) even after key out....
So, not just a fuse then... Where should I be pointing my mechanic..?
Thanks in advance. Paul
1987 Morgan Plus 8
Posts: 931 Likes: 47
Posts: 931 Likes: 47 |
Main / Full Beam / Horn failed this afternoon. Weird thing was that the full beam light stayed on for sometime (and couldn't be switched off) even after key out.... So, not just a fuse then... Where should I be pointing my mechanic..? Thanks in advance. Paul
Hi Paul, Tell your mechanic that your horn/dim/dip stalk has failed. That is the one on the left of your steering wheel. You can get another from the Factory or any Morgan dealer. Lorne
Posts: 1,764 |
I had a similar problem which was sourced to the Dim/Dip module on the 4/4. Removed the module and problem went away.
Phil Egginton 1979 4/4 4 seater
I had a similar problem which was sourced to the Dim/Dip module on the 4/4. Removed the module and problem went away. Paul, Phil could well be right. The same wires go through the dim/dip module too. Good thinking Phil! Lorne
Posts: 1,111 Likes: 17
Posts: 1,111 Likes: 17 |
Get an early triumph stag one as they are the same and only £12 on ebay, rarther than £70 plus vat. You need one with a slight kink.
Happend to me to.. I take it is a 80s plus 8, so the same period of switch as 87 car. Will
Posts: 94 |
Yup, an 1987 Plus 8...
Thank you very much for your advice guys!
1987 Morgan Plus 8
