5 members (Clipper, Davetherave, MartO, TBM, vincentvg), 281 guests, and 88 robots.
+8Rich 79
Topics49,871
Posts837,682
Rudolf
Page 3 of 3 1 2 3
When you tackle the spokes you must resign yourself to a long spell of tedium if you want to do it properly. The back of the rim and hub is simple by comparison, and can be protected simply by a regular wipe with an oily rag (light oil or WD40), or a less frequent treatment with wax (not polish). Old fashioned hard wax will stay on best in this environment. On the outside edge of the rim, there's a zone behind the spokes and in front of the raised part of the rim, which is very hard to get at, apart from a little finger wrapped in a duster. Where the spokes cross over, even shoe laces don't fit, so you'll need a range of tools to do a whole wheel. Large brushes work well enough to remove real grime with soapy water, but I make every effort not to get them that soiled in the first place.
When I had ss wires the cleaning was a pig but oh so worth while in the end. I used diluted Bilberry juice sprayed on and agitated by brush. If polishing - Autosol followed by a rinse and a wheel wax. regular wash with shampoo and a washing mit kept for the wheels only was all needed on a regular basis.
I also used to wipe the wheel inners clean too but not after EVERY run!
Now I have alloys and its a much easier job - my fingers are recovering after the mauling by the spoked wheels.
Great Thank You
Very helpful Thanks. Jeff (Pink)
Page 3 of 3 1 2 3
