4 members (Carbuilder, Davetherave, RichardV6, IcePack), 264 guests, and 35 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,043
#125130 04/03/13 03:41 PM
Dek Offline OP
The windscreen washer bottle on my 2010 +4 has died and needs replacing. The Mog is presently being looked after by my father-in-law in New Zealand. Rather than importing a Morgan part from the UK, does anyone know what the equivalent would be in some other make that could be sourced locally in NZ?
Bottle or pump ?
I replaced mine 2009 4/4 Sport with one from Holden's if they import to you.
http://www.holden.co.uk/displayproduct.asp?sg=&pgCode=040&sgName=Search&pgName=Washers+%26+Wipers&agCode=0700&agName=Washer+Bottles&pCode=040.049
About £30 with switch/wiring/tubing jets and all.
1972 4/4 2 Seater
Dek Offline OP
Thanks for the replies. Apparently it is the bottle that has split (I am abroad at the moment, which means I can't actually see the problem). I think it has been a faulty bottle from the outset as it started leaking soon after we bought it (from new). It was glued and now it is leaking again.
E
E
mine has just disintegrated, awaiting new from factory for 6 months!
2017 Mercedes Benz SLC 200 AMG.
2019 Mercedes Benz GLA 200 AMG
Now Ex-Mogger!
Have the 'split' bottles been allowed to become empty when the car is driven hard or on a hot day? Even though they are on the inlet side of the engine, it can get hot up against that bulkhead. Without liquid in the bottle to act as a heat sink, the bottle could be more succeptible to heat cracking...?
Stuart
Never had a problem with my '76 and the bottle was on the exhaust side of the car.
However, it was probably original, and somewhat thicker than they are now.
I did have a problem with a plastic coolant expansion tank (non OE) at one stage. The last of my spare brass tanks from LR/RR was still on the car when I sold it.
Leyland/Daf Sherpa also had brass expansion tanks. Not the right orientation for a Morgan but a piece of cake to attack with a blow torch and re-solder.
Same tank I believe Martyn. I fitted mine nearly flat on the bulkend above passenger footwell.
Really must dig out the photos... smile
