Topics48,339
Posts812,962
Members9,203
Posts: 22 |
Hi has any one got the same problem as me the speedometer is partly hidden by steering wheel, if so have you found any solution the steering wheel I have is 1 ins smaller in diameter than the original thank you in advance for reading this.
Les
Les Powell Morgan 4/4
Posts: 2,255 Likes: 2
Posts: 2,255 Likes: 2 |
There are a few solutions to this problem, an off set wheel being one and moving the speedo being another. What year is your car?
Posts: 22 |
I had the same problem. I'll post a photograph of my solution.
Posts: 35,773 Likes: 468
Posts: 35,773 Likes: 468 |
I can't see mine at all on a 2009 4/4 Sport with half tonneau (tucked away near the passenger eyeline) on which is mostly the way I chose to travel. I have the Rev counters unimpeded view and know what knots I'm doing per gear as far as speed limits are concerned. Solution be careful - well sometimes Hi has any one got the same problem as me the speedometer is partly hidden by steering wheel, if so have you found any solution the steering wheel I have is 1 ins smaller in diameter than the original thank you in advance for reading this.
Les
Posts: 14,009 |
I've just bought a GPS speedo the size of a small box of matches to fit down by the rev counter...hopefully it will do the trick!
Posts: 1,004 |
Wouldn't mind seeing a pic of that Jays. Sounds like a good solution. I've just bought a GPS speedo the size of a small box of matches to fit down by the rev counter...hopefully it will do the trick!
Posts: 14,009 |
I've not fitted it yet; I'll post a photo when I do. It was supplied by these people who advertised in MOG mag until recently. Digital-speedos
That sounds like an ideal solution - couldn't get the link to work so I'll wait until you send a pic. I've just bought a GPS speedo the size of a small box of matches to fit down by the rev counter...hopefully it will do the trick!
Posts: 14,009 |
Not sure what happened with the link! The company is Digital Speedos www.digital-speedos.co.uk which incidentally is the provider of the speedo/rev counter in Chunky4/4s racer as I discovered after buying it! The one I've got is the DS100 GPS Micro Speedometer.
