7 members (AlyMatt, piquet, +8Rich, BobtheTrain, TBM, GrumpyPa, PaulV),
247
49
Posts838,002
Posts: 83 |
Good day all, i seem to have acquired a squeak, not sure of location exactly sounds similar to a loose fan belt but leaves when i disengage clutch. Problem is also intermittent so difficult to pin down and chances are when take in to workshop it won't happen. Model 2012 Roadster with 4000 fun kms. Just a thought could it be the throw out bearing? Also can be quite loud at times and other times barely noticable. Any help/advice graciously received cheers Randall
Morgan Roadster 3.7 2012 Spruce Mica Green Saddle Brown Interior
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
It shouldn't be the throw out bearing after such a low mileage, but these things happen. Try to locate it when it's loud.
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
Could it be the belt on the alternator? Can you see if it's tight? (Engine off of course)  Is this a new 3.7 Roadster? I may have alternator issues on mine - and I know that Ford have had issues on the Duratec alternator.
+8 4.8
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
Do you take Vicky Butler-Henderson with you in the car? She squeaks when excited!!! It's one of the highlights of Fith Gear!
Posts: 83 |
it seems reasonably tight has maybe 1/2 inch movment in center between alternator and engine. more louder after have given it it a bit of a wind up. must be of the female persuasion
Posts: 1,947 |
Won't cure it long term, but some keen plant growers have a thing that sprays water on a plant's leaves. Spray the belt with the engine running - if it's that, silence will very quickly be effected.
It'll wear off just as quickly, but an industrial ironmongers will have some spray on belt dressing. Or you could mug a passing violinist as the belt dressing is usually basically just aerosol rosin (in solid form, applied to violin bows).
Gone to Porsche Part of the Furniture
Posts: 4,333 |
apply Engineers french chalk to either side of the "V" it will last a lot longer than any liquid
Posts: 360 |
Engine at idle in neutral. If the squeak goes with just enough light pressure on the clutch pedal to only just start to disengage the clutch, and stays not squeaking all the way to fully disengaged but then returns as soon as the clutch pedal is fully released then it is possible that the squeak is related to the clutch tangs/fingers and the release bearing. With a release bearing just catching the clutch tangs then sometimes a sort of ringing can be set up as the tangs/fingers vibrate at high frequency, then with a bit more contact of the release bearing they are stopped from ringing. If it is that then there is no great problem. The ends of the tangs/fingers will wear slightly over many many miles - just a thought. PJB
Posts: 83 |
Many thanks guys will give ideas a go,i didn' mention that the car is moving when squeal arrives so not going to be an easy find. But will just have use car more maybe i can wear it out. Cheers
Posts: 27,838 Likes: 764
Posts: 27,838 Likes: 764 |
If it squeals on acceleration it could be a loose fan belt as you suggest mine does it when very cold.
