4 members (Zach, JohnHarris, Socalm3w, TBM), 279 guests, and 37 robots.
+8Rich 94
John V6 50
Posts837,997
rockabilly john
#127031 16/03/13 06:12 PM
sawman Offline OP
I discovered today that my brake lights(both of them) arent working.
I have checked the fuse, which is ok. I have not checked the bulbs as yet, but whilst its both lights that are not working, my guess is that its not that simple.
I am guessing it could be the switch thats failed, where would I find this on a 1988 4/4 4seater?
Any other ideas as to possible issues gratefully received!
The 2xBrake switches on my 2009 Sport are on the rear of the pedal. One for brakelights tother to let the ECU know not to supply fuel.
If not there on yours we will think again. coffee
On an early car it will be a pressure actuated switch in the brake hydraulic line. On my Plus 8 it was in the engine compartment on the driver side towards the front.
Andy
Andy #127054 16/03/13 11:04 PM
Andy
Same on my '76 4/4.
On my 2002 +8 I had my pressure actuated switch replaced with a mechanical one, got to the point where I was replacing them every service. Cost approx £50 incl fitting.
Les Ellis
Putting the Plus 8 burble into the Cheshire countryside.
2002 +8
2018 Audi S1
My 2005 roadster got through pressure swithes with monotonous regularity. In the end I wired a mechanical swith replacement. I used a fridge light switch (reasoning that they're designed to carry 240volts and work about 3 million times before failing) to a small block of wood and fixed that in front of my brakepedal. It works perfectly. Shortly after I did it the factory changed to a professional version of what I'd done. I think they have a spy camera in my garage.
nick
sawman Offline OP
cheers chaps, after posting I had a perusal of morganatica and gomog, I have been able to locate the switch, and happily it seems one of the connectors was loose - so all fixed now
Good fix. Well done.
Ian
Andy #127087 17/03/13 09:47 AM
Andy
Ditto on my 97 +4
Glad you got it fixed
Good one Simon.
