5 members (RickyH, RichardV6, JohnHarris, banbury, Image), 230 guests, and 25 robots.
+8Rich 99
Luddite 54
Topics49,905
Posts838,098
Page 15 of 16 1 2 13 14 15 16
Well I finally picked it up yesterday. God in heaven it can shift :
David
2020 Roadster 3.7 Dove Grey.
Congrats -- Looks lovely!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Originally Posted By Neilda
Originally Posted By Jays
Looking at M-K's website it says that the stalks will fit with the standard plastic cowl so you shouldn't have any problems. I seem to recall a photo of the stalks without the cowl and it looked as though M-k uses the standard plastic switch base which screws to the steering column. I will probably be tempted at some stage when I make a new dash.
I'm not sure if the new Roadster's canbus system uses the same switch base... I guess it must.
Losing the intermittent wipe wouldn't be an issue.
This is what Morgan currently use...the Freelander Series 1 switch......so I'm told, unless they have recently changed it.
P.S. David...that looks wonderful!
Hope you enjoy your beauty David!
Great to have it finally home! smile
Thanks for the pic of the stalks Jay....
+8 4.8
To be known as "QuickBlack" from now on?
Jeremy
2009 4/4 Sport Green
And nothing else !
Congrats! cheers
All you need now is the weather...
Ian
3.7 Roadster
4" Ruston Procter SD Tractor
1905 Merryweather steam fire engine
I've just exchanged emails with Matthias about the stalks. They are just plug and play and fit the standard factory steering column shroud as well. He outsources the stalks at the moment but is producing his own ones which will be a little cheaper and restyled in about 6 to 8 weeks. I'll be ordering a set.
Cool. Would you let me know when you do?
+8 4.8
Quickblack!
Good name - I like that smile
Thanks everyone for your comments.
Very happy with how the car handles. It is a little stiff and will no doubt get a bit loose over time. And of course there are a hundred different things to get used to like how to handle the car, getting in and out , use of the hoods, etc.
I could not resist pushing it on the motorway to test it's capabilities so I shifted down to 5th gear, floored the accelerator to over 3000 revs and the engine produced a lovely howl and left everything else standing grin2 I must behave myself evil
David
