1 members (RedThree), 194 guests, and 37 robots.
+8Rich 101
John V6 57
Topics49,911
Posts838,152
Georgetoad, woolfie
At the front the brackets are entirely different. The track rods pass through the over-rider brackets so you must disconnect the trackrod ends at the stub axle to fit. The other thing to beware of is that the brackets changed when the track rods went from above the steering arms to below, and in the case of the latter, the hole through which the track rod passes is deeper. It would be essential to check clearance because if you get this wrong, the trackrod will foul the bracket on rebound and it could stiffen the steering enough to cause an incident.
At the rear, the brackets are totally different, but it's a bit easier. The factory sell brackets in the on-line shop to change from full bumper to over riders using the same locating holes. These brackets are not the same as when over-riders are fitted from new, but makes the rear much easier to do.
Some older Morgans, and I do mean older, had full front bumper and over-rider rear, which to my mind looks odd.
But then I don't find full bumpers very attractive, I think it masks the lower front wing lines too much, although I don't much care for the high naked front either, which is why I fitted the spoiler.
Originally Posted By Neilda
I chose full bumpers based on my wife's parking technique.
It's not that she drives the Morgan, but I've used her as a reference of how others might park near my car. smile
+1 plus mine based upon a cluttered garage unlike Dave W's
I also prefer them
Are these "Frog-Eye" sprite rear overriders?
Barmar
Hi Barmar and welcome to TM. The overriders that fit to the bumpered cars certainly look like Sprite front ones. The standalone ones the the factory now fits I think are bespoke although similar to Sprite rear ones,
Edit: Had another look at the AH parts list and yes...the AH "rear "Bumperette" looks very like the Morgan overrider!
Is it possible to go from Overriders to Full width bumper at the front?
Yes you just need the change parts. I guess any dealer can supply those or indeed someone on here who swung the other way.
