7 members (John V6, JohnHarris, nestor59310, IcePack, CBY, BobtheTrain, Grumpy2), 314 guests, and 31 robots.
+8Rich 101
John V6 57
Topics49,911
Posts838,153
Georgetoad, woolfie
#129289 31/03/13 09:21 AM
S Marsh Offline OP
Hi i got a 2003 plus 8
Is it normal on the front suspension if you push down on the front bumper there is no movement in the suspension but plenty if you left up
Thanks
How hard are you pushing down?
Suspension is 'Firm'...
I would say no. Try pushing on the top wing you should get a few inches of movement downards.
If not either you have very strong springs fitted or something is seized. Try claening off the old grease & then greasing the suspension.
http://www.gomog.com/allmorgan/front.html
S Marsh Offline OP
I can stand on the front and no movment
Then something is wrong. Try greasing I guess but clean out the old gease first on the lower springs in case that crud is blocking the movement.
S Marsh Offline OP
Clean all the suspension and re greased and if you jack the car up and down it all
Moves but if i jump on the front it still no movement on the bottom spring there is a number Elbach 48/00 Morgan Rebound and a blue spring on top
What on earth are you jumping on? shocked2
Jays #129372 31/03/13 05:18 PM
S Marsh Offline OP
Seating on the front bumper ,the car was fine in nov so used it yesterday
It not right on the road
Definitely not right!
Do you have covers over the lower springs to prevent road crud getting onto the lower ends of the king pins?
Try greasing as you turn lock to lock.If the grease won't go in, use a bit of heat carefully applied to the stub axle. It will melt the grease inside - not too much heat though!!
At 2003 it could have those "nylon" bushes.
