1 members (Plus Four Guy),
211
36
Topics49,911
Posts838,152
Posts: 12 |
Hi i got a 2003 plus 8 Is it normal on the front suspension if you push down on the front bumper there is no movement in the suspension but plenty if you left up
Thanks
Posts: 28,912 Likes: 354
Posts: 28,912 Likes: 354 |
How hard are you pushing down? Suspension is 'Firm'...
Posts: 27,846 Likes: 765
Posts: 27,846 Likes: 765 |
I would say no. Try pushing on the top wing you should get a few inches of movement downards. If not either you have very strong springs fitted or something is seized. Try claening off the old grease & then greasing the suspension. http://www.gomog.com/allmorgan/front.html
Posts: 12 |
I can stand on the front and no movment
Then something is wrong. Try greasing I guess but clean out the old gease first on the lower springs in case that crud is blocking the movement.
Posts: 12 |
Clean all the suspension and re greased and if you jack the car up and down it all Moves but if i jump on the front it still no movement on the bottom spring there is a number Elbach 48/00 Morgan Rebound and a blue spring on top
Posts: 14,009 |
Clean all the suspension and re greased and if you jack the car up and down it all Moves but if i jump on the front it still no movement on the bottom spring there is a number Elbach 48/00 Morgan Rebound and a blue spring on top What on earth are you jumping on?
Posts: 12 |
Seating on the front bumper ,the car was fine in nov so used it yesterday It not right on the road
Definitely not right! Do you have covers over the lower springs to prevent road crud getting onto the lower ends of the king pins?
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Try greasing as you turn lock to lock.If the grease won't go in, use a bit of heat carefully applied to the stub axle. It will melt the grease inside - not too much heat though!!
At 2003 it could have those "nylon" bushes.
