Posts837,278
Posts: 472 |
Peter: Wobble is not really a 'problem', hardly notieable - could actually be my wire spoked wheels that needs centering (if that's the correct expression...). I haven't had the time to check everything yet, but I will when I rebuild the front.
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS -04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
Posts: 472 |
If you are interested in discussions about Rising Rate Suspension contra Double Wishbone Suspension, this is the topic: http://www.talkmorgan.com/ubbthreads.php/topics/121833/Double_Wishbone_IFS_for_Classi # Post121833 I'm still eagerly awaiting the Rising Rate Suspension kit to become available
Posts: 12,256 Likes: 317
Posts: 12,256 Likes: 317 |
Kevin Vernon now has the Suplex rising rate conversion kit in stock, mine is being fitted next Friday
Posts: 3,480 Likes: 42
Posts: 3,480 Likes: 42 |
Hamwich, Would really appreciate your considered opinion on this mod when you have done a few miles ( I suppose after the next weekend as I suspect you'll not be able to resist trying it out!!!)
cheers from a sunny Ireland -- had a great blast in the Mog this morning!!
Posts: 28,888 Likes: 350
Posts: 28,888 Likes: 350 |
We might be able to run some back to back comparison tests on a Highlands tour in late June...  That's if I can keep up with that GM powerplant Tim has in his 4/4
Posts: 360 |
So how will you assess? Maybe - who has the worse back/neck pain after hundreds of miles on Scottish roads or who comes through fast bumpy corners still with a smile on their face. I don't remember many Morgans hanging on my tail in 2011 through the Highlands, and those were just the prototypes.........PJB ;-)
Posts: 472 |
Kevin Vernon now has the Suplex rising rate conversion kit in stock, mine is being fitted next Friday Thanks for info, Hamwich  and good luck with yours.
You were too busy burning up 911's to notice whether any Mogs were keeping up Peter
Posts: 360 |
Yea, I got him on the corners, the look on his face was a picture - but the slightly breathed on CVH was no match on the straights, good fun though - the 2.0 Zetec might have more chance. Others might be interested in that the Zetec 2.0 litre can be installed in place of the 1.6 CVH using the following from the CVH:- gearbox, clutch, exhaust manifold & system, inlet manifold, Weber DFT 32/34, engine mounts, rad, alternator and other bits and bobs and still give over 100 bhp at the rear wheels with a calculated 138 bhp at the flywheel from the rolling road test. Brmmmmmmm! PJB.
Posts: 517 |
I am interested in the rising rate front suspension conversion from Suplex. Has anyone fitted these springs and what is the result?
Titus 2007 Morgan +4 4seater
Titus
2007 +4 4 seater 2017 Mini Cooper 2007 VW Camper 1996 Honda TRX300 2012 Husqvarna 216
