Morgan Aero 8
6 members (Morganmike, High Hamster, deano, RichardV6, Bobajobbob, bmgermany), 255 guests, and 88 robots.
+8Rich 78
Topics49,872
Posts837,704
Rudolf
#130352 06/04/13 06:18 PM
DJWuk Offline OP
Was a bit shocked today when I was quoted the normal annual service cost for an Aero 8. Appreciate it's not your normal run of the mill car and it appears some bodywork has to be removed
Can I ask what aero owners expect to pay for an annual service and any recommendations of specialists around Worcestershire, Warwickshire, Gloucestershire areas please.
I'm assuming any cars I view, should have a service every year, from a reputable Morgan garage / specialist ?
Dave
le Asbo du Bling
le Asbo du Bling
Dave what were you quoted?
From memory typical cost for me has been £600 -£700 for the annual service, sometime a little more if parts needed.
Given the cost of servicing most super cars and even TVR's seems a fair price.
Slowly going green
DJWuk Offline OP
£2,500
I suppose the factory would be a good place to start - try speaking to Mark Baldwin. Alternatively, Williams can probably help.
Pete
le Asbo du Bling
le Asbo du Bling
Are you sure it's an Aero and not Boshlys Ferrari you're getting serviced?
Slowly going green
Gin Offline
Around £1000 depending on parts needed.
DJWuk Offline OP
Good to see some lower numbers.
Can I ask if these services included steps such as wings off etc, as recommended by factory for an annual service, or are they a subset of work carried out ? Just trying to establish why I was quoted so much more.
Dave.
Goodwood Drifter
Goodwood Drifter
man man man, did I have a laugh rofl
removing body-parts from the Aero: can be done in about 2minutes!!!!!!! juggle
my Max was around £550 for a "big service"
thank you so much BMW!!!!!!
Steven
now: +fourLM62
This is circa what I paid last year for a service at the factory. I don't have the bill to hand but will check tomorrow.
Unless you get hit by a hefty parts bill (unusual), and even then the parts aren't generally expensive, your figure of £2,500 seems excessive.
DJWuk Offline OP
Feeling much better now. For a mo I thought I had chosen the wrong car, but if I can get a service for amounts mentioned above, then I'm smile
