8 members (Bilymog, linklaw, DavidR, Strathaven, Bunny, Graham, G4FUJ, lez, TalkMorgan), 184 guests, and 36 robots.
+8Rich 99
John V6 55
Topics49,906
Posts838,104
Page 3 of 4 1 2 3 4
I should have made it clear that I was referring to the Aero blades - these are different to the trad range I believe.
Oops!
New joints for old!
Ale_72 Offline OP
Oops!
I am not so sure, but if they are Aero specific blades, I am even more interested! laugh
Ale_72 Offline OP
So... After some investigation it seems I understood but not solved) the issue.
The "male" part (2) coming from the "traditional" Morgan has a different milling (?) from the female one (1).
Beside this the housing of (1) is not a snug fit.
It seems that chrome arms (for Aero8) have a tighter fitting.
We will try with those as soon as my dealer get them from the factory.
Meanwhile we did the arm bending and the thing got a little bit better. We did not make the rain-x treatment since we decide to wait for the new arms to better understand the difference.
That is very useful. The fit between 1 & 2 on your schematic is very poor on my Aero - there is a lot of play and I have solved it (temporarily) with gaffer tape. There is still a lot of play in the linkages which means that the 'rest' position of the wipers varies.
The blades I sourced from ebay
28" BLACK Silicone Rubber Wiper Blades Refills 2 Pack £4.95 which you simply cut to fit.
The securing clip will need enlarging
You can just see the irregular filing that I did!
Now 2/3 wipers are perfect and actually clear the screen, one still needs further tweaking.
Good luck
New joints for old!
Ale_72 Offline OP
My plan is the following.
1. driving enjoying the sun
2. see what happens withe the chrome arms when/if they arrive
3. try to make it tighter by using what in Italy is named "teflon tape" (PTFE tape???)
I have a spare set - I replaced the chrome with black!
New joints for old!
The center wiper on our car needs a slightly longer arm. When it goes to the end of it course the end of the blade runs off the bottom of the screen.
Ale_72 Offline OP
Didn't you notice any difference between the two?
Do you remember how much did you pay for them?
The Black (Aeromax) arms were slightly better - a bit less gaffer tape - but not by much.
Price for blades and arms (2010)£109 inc VAT for all 3.
spend
New joints for old!
Ale_72 Offline OP
Finally the combination of gaffer tape + twisting a little bit wiper arm it worked.
I do not know if it will work forever but for now it's great.
Page 3 of 4 1 2 3 4
