2 members (Zach, DCH),
222
33
Topics49,911
Posts838,147
Posts: 96 |
For want of a better phrase - it is a case of 'they all do that sir'?
Backing off the (light) throttle onto the brake, or vice versa, they car audibly and physically 'clunks'. Engine or gearbox mount possibly? Only happens at low speed and having only ever driven it 3 times and for 150 miles in total, I am not sure whether it has always done this!
1994 Plus 8
Posts: 96 |
1994 Plus 8 in case that matters...
1994 Plus 8
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
It shouldn't do it - but I don't know what the problem might be.
+8 4.8
Posts: 103 |
Mine's a 1993 Plus 8 and it definitely does not do that. I suggest you check your prop shaft UJ's.
1993 Plus 8 Connaught Green Various older cars and motorcycles Big American Bulldog
Posts: 3,643 |
Do you have alloys or wire wheels ?
Posts: 3,643 |
If you have wire wheels check wheel nut is tight, if tight check splines as they may be worn. If possible get someone to listen to hear or watch for the clunk.
Posts: 96 |
I have wires - will check the nuts before my next drive. Sad to have a problem so early, hopefully something minor... but sound like it may not be. Just had two very expensive driveshafts on my other car
1994 Plus 8
Posts: 360 |
Check the U bolt nuts on the rear axle for tightness, the axle can move fore & back &/or rotate with power on & off and give a 'clunk'. Did on mine after some abuse! PJB
Posts: 96 |
No abuse except living in West London and having potholed roads and speed bumps everywhere!
Who and where is my local trusty specialist from the West London area?
1994 Plus 8
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Check the U bolt nuts on the rear axle for tightness, the axle can move fore & back &/or rotate with power on & off and give a 'clunk'. Did on mine after some abuse! PJB I'd do this. Think GoMoG have a watch point article on this too.
Richard 1976 4/4 4 Seater
