3 members (Rog G, Zach, DCH), 213 guests, and 38 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,147
#131780 15/04/13 05:08 PM
marcos Offline OP
For want of a better phrase - it is a case of 'they all do that sir'?
Backing off the (light) throttle onto the brake, or vice versa, they car audibly and physically 'clunks'. Engine or gearbox mount possibly? Only happens at low speed and having only ever driven it 3 times and for 150 miles in total, I am not sure whether it has always done this!
1994 Plus 8
marcos Offline OP
1994 Plus 8 in case that matters...
1994 Plus 8
It shouldn't do it - but I don't know what the problem might be.
+8 4.8
Mine's a 1993 Plus 8 and it definitely does not do that. I suggest you check your prop shaft UJ's.
1993 Plus 8 Connaught Green
Various older cars and motorcycles
Big American Bulldog
IanA #131790 15/04/13 05:48 PM
Do you have alloys or wire wheels ?
Ian
If you have wire wheels check wheel nut is tight, if tight check splines as they may be worn.
If possible get someone to listen to hear or watch for the clunk.
Ian
marcos Offline OP
I have wires - will check the nuts before my next drive.
Sad to have a problem so early, hopefully something minor... but sound like it may not be. Just had two very expensive driveshafts on my other car frown
1994 Plus 8
PJB Offline
Check the U bolt nuts on the rear axle for tightness, the axle can move fore & back &/or rotate with power on & off and give a 'clunk'. Did on mine after some abuse! PJB
PJB #131814 15/04/13 08:05 PM
marcos Offline OP
No abuse except living in West London and having potholed roads and speed bumps everywhere!
Who and where is my local trusty specialist from the West London area?
1994 Plus 8
PJB #131822 15/04/13 09:27 PM
I'd do this. Think GoMoG have a watch point article on this too.
