Topics48,379
Posts813,562
Members9,215
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
I wonder if the new Suplex system that's been discussed on other threads might help?
I don't really know much about suspension. I've never had to.
+8 4.8
Posts: 1,440 Likes: 8
Posts: 1,440 Likes: 8 |
I have had a few nasty shocks in mine, Neil. The other day it crashed so violently that I really thought I had done some damage. It sounded like God's cutlery tray. It was ok though. Experiences like this really do make you think about a suspension upgrade.
David 2020 Roadster 3.7 Dove Grey.
Posts: 859 Likes: 1
Posts: 859 Likes: 1 |
Does any one know the part number for the AVO shocks for the front? Their website just shows the Plus 4 and no other models. I am interested for a 2009 Roadster.
Honda S2000 Lexus UX 250h Toyota Auris Hybrid
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
You need the Rutherford AVO's - different settings for Morgans. http://www.newelmsmorgan.com/rutherford-parts.htm
Posts: 360 |
Good results on a 3.0 Roadster with the SUPLEX front suspension. The 3.7 is not that much different so should also work well. PJB.
It's all a bit confusing.... Particularly as I don't really know much about suspension.
The Avo's are a shock absorber replacing the existing ones?
The Suplex is a similar idea which also includes shock absorbers?
+8 4.8
Do you think it would help with the bottoming out issue too Mike? Is it adjustable?
Thanks...
+8 4.8
Posts: 26,770 Likes: 429
Posts: 26,770 Likes: 429 |
How are the tyre pressures?
Tyre pressures are 24psi.
+8 4.8
Posts: 28,434 Likes: 183
Posts: 28,434 Likes: 183 |
Probably about right Neil. Are you of a reasonably stout build? If so, you might want a little extra air. Your car is heavier than mine by a reasonable percentage and I weigh in the region of 130Kg (yes, I need to lose weight - about a third of that!  ). I run 24 front 26 rear for normal road use.
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
