11 members (Jensen1960, Rex_tulips, Gerry Seale, IcePack, RichardV6, +8Rich, Mauli, brownbaker, Grumpy2, Image, Tresco), 271 guests, and 37 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,328
Members9,215
Page 4 of 4 1 2 3 4
I too am curious as to see how you have attached the mud guard, as this will be one of my first projects.
Charlie, Former Editor
NeilL #134511 04/05/13 09:57 PM
Originally Posted By m3boy
As posted last week I decided to experiment with a rear mudguard for the M3W coffee
I bought a plastic trailer mudguard for a 15" wheel - a full radius type (rather than half a hexagon type)
Taking off the ally plate the "new" guard was fitted using the same fixing holes and bolts.The guard fitted in a perfect radius round the wheel and met the rear chassis bang on the base area - fixed with two Hex head wood screws to the ash.
Its works a treat - as the test drive yesterday demonstrated. happy3
U just need a slight mod round the drive belt area and to allow
for suspension travel.
This will stop the seat belt issue - forces road debris/water etc downwards, not into the transmission area and stops debris being thrown up into the covered boot area. innocent
so bingo!An easy mod - which could be simply reversed to original if necessary. cheers
This is good. The problem with road mung and dirt has vexed me and this is a relatively easy fix. Between this and removing the seat back and tightening up the joins and using silicon here and there will greatly relieve the general muck. I have noticed that the dirt I receive from the road is negligible but the crap that comes through the cracks from the rear is the telling story. I can wipe it down every day but it comes back!
It does not encourage guests!
Thank you a million times!
I have spent hours looking for this thread, trying to find this photo, and I totally forgot that it was in this section and not the 3 Wheeler section.
I have a similar hugger type trailer mudguard fitted plus some additional shielding behind the seat belts. It makes a world of difference though you still need to take out the boot liner fairly regularly to clean off the road crud below it. At least now I don't get the feeling that the car is eating itself from the back wheel forwards!
Hi - just having a look under the load tray and working out how to fit a plastic mudguard - there is quite a lot of suspension travel - won't fixing one end to the swinging arm in place of the alloy guard and the other end to the body result in a broken mudguard ?
Marc
"won't fixing one end to the swinging arm in place of the alloy guard and the other end to the body result in a broken mudguard"
Not so far is probably the best answer!
In reality the movement at the attachment point to the swing arm isn't that large but what lifespan these mudguards will have remains to be seen.
Thanks Calum
HJP Offline
I was wondering about this too before I fitted mine, I've now done around 1500miles since fitting it ,a lot of the time on bumpy roads. No problems so far :-)
Hugh
Page 4 of 4 1 2 3 4
