Topics49,880
Posts837,755
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Glad to hear all is sorted.
Richard 1976 4/4 4 Seater
Posts: 472 |
Thanks Richard
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS -04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
Posts: 472 |
Done  - but not without a certain amount of not anticipated work... There was absolutely no way of fitting the lower end without detaching the lower 'mounting'(?) from the brake shield first. To detach it I had to take off the drums and release the shoes a bit in order to hold the screws with a spanner. After that everything was easy, just a lot of turning of nuts and bolts... Has anybody else had trouble fitting the AVO dampers on a 4/4? (-99)
Sounds great - well done. Any photos?
Posts: 472 |
 Not enough space...  Mounting bolts - had to be detached. Also shows that I had to leave out a washer (inner) to make the locking nut work - will attend to this later...  Both finally done (4 hrs) - went for a quick drive today and it works absolutely perfect. 2 clicks for now.
Thanks for the photo - at least all is working well
