6 members (aerotaff, MATTMOG, MJF, Barkbark, Julian BB, WAFU_Tom), 305 guests, and 86 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,757
Glad to hear all is sorted.
Lecat Offline OP
Thanks Richard smile
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
Lecat Offline OP
Done thumbs - but not without a certain amount of not anticipated work...
There was absolutely no way of fitting the lower end without detaching the lower 'mounting'(?) from the brake shield first. To detach it I had to take off the drums and release the shoes a bit in order to hold the screws with a spanner. After that everything was easy, just a lot of turning of nuts and bolts...
Has anybody else had trouble fitting the AVO dampers on a 4/4? (-99)
Sounds great - well done. Any photos?
Lecat Offline OP
Not enough space...
Mounting bolts - had to be detached. Also shows that I had to leave out a washer (inner) to make the locking nut work - will attend to this later...
Both finally done (4 hrs) - went for a quick drive today and it works absolutely perfect. 2 clicks for now.
Thanks for the photo - at least all is working well smile
