1 members (deano), 154 guests, and 15 robots.
John V6 63
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,604
Page 17 of 19 1 2 15 16 17 18 19
That is a grat photo, works really well in black and white.
Ha! Awesome...you obviously know your way around a camera - professional?
1965 Plus 4
2008 997 Turbo Cab
1981 Alfa Spider
1954 Austin Healey 100 (SOLD)
2013 M3W (SOLD)
I ordered a Pool ball gear knob - but it will not fit ( screw fix on the M3W way too big a thread) ooo if any one has a fix - please let me know!! cheers
Neil
One of the eBay pool ball knobs per the above link? If there is fit issues, than my mind may be a changing.
Charlie, Former Editor
le Asbo du Bling
le Asbo du Bling
Can you measure the size of the shift stick to work out the diameter?
Slowly going green
HJP Offline
I'm hoping to change mine for a wooden one but so far haven't been able to get the original one off , I've seen a picture posted on here of the threaded collar, but can't seem to shift it, any helpful suggestions? Or am I just not trying hard enough ?!
Hugh
le Asbo du Bling
le Asbo du Bling
The knobs in 2 parts. The lower section about 8-10 up should unscrew. Once you've done this you should be able to get to the grub screws to take it off. Good luck.
Not sure if this helps or not but I seem to recall when last at the factory noticing that the new gear lever ( those with the new layout) aren't threaded. May have been my imagination but can't find the pictures now.
Slowly going green
HJP Offline
Thanks , mine is the original layout, seems that I need to use more force ...
Hugh
Blake Offline OP
Guilty as charged.
I'm a professional architectural photographer.
You guys can check out my work at www.blakemarvin.com
Enjoy
blake
sfmorgan.tumblr.com
le Asbo du Bling
le Asbo du Bling
This might help
Slowly going green
