7 members (linklaw, JohnHarris, sewin, Barkbark, Moggo, JMcL, TBM),
76
Old Book
Topics49,941
Posts838,615
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
That is a grat photo, works really well in black and white.
Richard 1976 4/4 4 Seater
Posts: 414 Likes: 6
Posts: 414 Likes: 6 |
Ha! Awesome...you obviously know your way around a camera - professional?
1965 Plus 4 2008 997 Turbo Cab 1981 Alfa Spider 1954 Austin Healey 100 (SOLD) 2013 M3W (SOLD)
Posts: 6,538 |
I ordered a Pool ball gear knob - but it will not fit ( screw fix on the M3W way too big a thread)  if any one has a fix - please let me know!!
Neil
Posts: 1,664 |
I ordered a Pool ball gear knob - but it will not fit ( screw fix on the M3W way too big a thread)  if any one has a fix - please let me know!! One of the eBay pool ball knobs per the above link? If there is fit issues, than my mind may be a changing.
Charlie, Former Editor Morgan Owners Group - Great Lakes
Posts: 3,843 Likes: 11
le Asbo du Bling Talk Morgan Addict
Posts: 3,843 Likes: 11 |
I ordered a Pool ball gear knob - but it will not fit ( screw fix on the M3W way too big a thread)  if any one has a fix - please let me know!! Can you measure the size of the shift stick to work out the diameter?
Slowly going green
Posts: 1,213 |
I'm hoping to change mine for a wooden one but so far haven't been able to get the original one off , I've seen a picture posted on here of the threaded collar, but can't seem to shift it, any helpful suggestions? Or am I just not trying hard enough ?!
Hugh
The knobs in 2 parts. The lower section about 8-10 up should unscrew. Once you've done this you should be able to get to the grub screws to take it off. Good luck.
Not sure if this helps or not but I seem to recall when last at the factory noticing that the new gear lever ( those with the new layout) aren't threaded. May have been my imagination but can't find the pictures now.
Slowly going green
Posts: 1,213 |
Thanks , mine is the original layout, seems that I need to use more force ...
Hugh
Posts: 417 |
Guilty as charged. I'm a professional architectural photographer. You guys can check out my work at www.blakemarvin.comEnjoy Ha! Awesome...you obviously know your way around a camera - professional?
blake sfmorgan.tumblr.com
Thanks , mine is the original layout, seems that I need to use more force ... This might help
Slowly going green
