7 members (John V6, How, DCH, MartinB60, IcePack, Luddite, TBM),
362
42
Posts837,279
Posts: 472 |
Thanks Gerry, I'll try to keep it up - the spell check works well I think
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS -04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Welcome Lecat.
The rising rate front spring kits are almost ready and I have ordered a set. I have had a whole saga relating to ride height on a 2012 Plus 4 and have already had the springs changed under warranty. The ride height problem has been resolved but I am not entirely happy with the, now, rather firm ride. I have decided to fit aftermarket improved suspension to resolve both problems.
Send me a PM with your email address and I will send you all the information I have.
Posts: 472 |
shiremog: I will listen for the squeak - what kind of grease and what method do you use when greasing your bushings?
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Hi & welcome. GoMog has lots on front end suspension.
Posts: 477 |
Hello Lecat. Wishing you many happy miles in you Morgan.
Dave
Posts: 472 |
Thank you all again - I will surely enjoy myself both here and on the road!
Posts: 534 |
shiremog: I will listen for the squeak - what kind of grease and what method do you use when greasing your bushings? I used moly grease. My Roadster didn't have the oiler, just a single grease nipple on each side. The current Roadster has 2 nipples on each side, one at the top of the king pin & one on the hub, so more work to service this one  I've also fitted gaiters over the springs to keep some of the weather off the king pins. Ian
3.7 Roadster 4" Ruston Procter SD Tractor 1905 Merryweather steam fire engine
I use castrol cl grease as it is designed to be water resistant & for older style suspension systems.
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
I use castrol cl grease as it is designed to be water resistant & for older style suspension systems. +1- until I sold it, no KP's on the Lotus
Posts: 534 |
