9 members (Image, MartO, sprinty, Plus Four Guy, Alan Patterson, MartinB60, RedThree, Simon, AMorgan),
210
99
Topics49,872
Posts837,686
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
So a solution has to be found to getting a bleed tube on to the elusive nipple and then slacken the flipping thing!
The joys of ownership  Good luck!
Richard 1976 4/4 4 Seater
Posts: 12 |
Great ... thanks Keith. I'll see if I can find a solution from this start point.
___________________________
Car: year 2000 4/4 2 seater
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
"Your starter for ten, no confurring!"
By the way I take no responsibility if the information is wrong, but it is the best I can get and surprised that no-one else has come up with anything.
Keith
Car 54 - 'Le Mans 62' 4/4 Supersport OxMog Member (and associated with CranMog and SwanMog)
Posts: 28 |
Try breaking the bleed screw and then fit the tube,you can turn the bleed screw much easier.that way.
Posts: 12 |
I've now found the bleed screw on my year 2000 4/4 1800 Zetec ... it's behind a square rubber blanking plug in the bellhousing on the lower nearside (not the offside). At last!
Posts: 28,904 Likes: 352
Posts: 28,904 Likes: 352 |
Well found Sir!!
Well found Sir!! +1
I've now found the bleed screw on my year 2000 4/4 1800 Zetec ... it's behind a square rubber blanking plug in the bellhousing on the lower nearside (not the offside). At last! Well done that man! I will wait for any more praise until I can't see it myself on my car....is it easy to get the bleed pipe on?
Keith
Posts: 12 |
Hello Keith ... yes, the extended clutch bleed screw is right there when you take off the rubber blanking plug. Bleed pipe fits straight on without any gymnastics!
Keith
