Topics49,866
Posts837,587
Posts: 1,704 Likes: 35
Posts: 1,704 Likes: 35 |
Is anybody in the magic circle? I need a magician. Parcel in the post this morning from Mr Rutter with my new £3.50 replacement clutch return spring. So this afternoon I eagerly dived down into the foot well and stripped the pedal assembly out. As I was removing it I spotted it - OMG! Today’s conundrum. Take a look at the second photo. Does anybody know how the spring is supposed to be replaced? Has anybody changed one? Even if it could conceivably be unwound to enlarge the i/d it would surely over stress the tangs. Its very stiff. Broken spring New spring to be assembled???
Roger 2011 Plus 4
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
It's a bit like putting a key on a key ring, you need to splay the first coil enough to force the short leg of the pedal between then keep rotating the spring until you have wound it onto the shaft, hopefully facing in the right direction so it pulls the pedal up!
Posts: 14,009 |
Blimey! Knowing Morgan I suspect that you will need a complete new clutch pedal!
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
If you blow this up a tad it shows the spring's positioning fairly clearly. Assemble it with the stub underneath and then clip the longer part of the spring round the pedals afterwards looks like the way forward.
1972 4/4 2 Seater
Posts: 14,009 |
Yes...i dashed out to photograph my pedal thinking that would be the answer! A tough of wizardry is really the answer unless Easter has the correct one...which probably needs very strong fingers!
Thanks for the reply’s and thanks Easter. That is cunning, I think it might work!
Roger 2011 Plus 4
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
I think Easter's cracked it. Uncle Melvyn will advise too I'm sure if asked.
Richard 1976 4/4 4 Seater
Posts: 14,009 |
Thanks for the reply’s and thanks Easter. That is cunning, I think it might work! Easter and his cunning plan.........is he the Baldrick of TM?  P.S. talking of Baldrick.....I wonder how Rowan Atkinson feels after only getting an OBE in the Queens Honours whilst his ex "servant" got a knighthood? !!
Posts: 1,337 |
Thanks for the reply’s and thanks Easter. That is cunning, I think it might work! Easter and his cunning plan.........is he the Baldrick of TM?  P.S. talking of Baldrick.....I wonder how Rowan Atkinson feels after only getting an OBE in the Queens Honours whilst his ex "servant" got a knighthood? !! Probably ok his ex "servant" was recognised for his many activities rather than simply acting. He was on a certain parties national executive etc. in many ways a better actor Atkinson, always surprised Hugh Lawrie not better recognised
P.S. talking of Baldrick.....I wonder how Rowan Atkinson feels after only getting an OBE in the Queens Honours whilst his ex "servant" got a knighthood? !! I thought the same but then as already noted he has been involved in politics, restortations, historical studies...
