5 members (deano, TBM, JMcL, linklaw, JohnHarris), 202 guests, and 94 robots.
+8Rich 78
Topics49,872
Posts837,695
Rudolf
Originally Posted By minikeefy
So a solution has to be found to getting a bleed tube on to the elusive nipple and then slacken the flipping thing!
The joys of ownership smile
Good luck!
Great ... thanks Keith. I'll see if I can find a solution from this start point.
___________________________
Car: year 2000 4/4 2 seater
"Your starter for ten, no confurring!"
By the way I take no responsibility if the information is wrong, but it is the best I can get and surprised that no-one else has come up with anything.
Keith
Try breaking the bleed screw and then fit the tube,you can turn the bleed screw much easier.that way.
I've now found the bleed screw on my year 2000 4/4 1800 Zetec ... it's behind a square rubber blanking plug in the bellhousing on the lower nearside (not the offside). At last!
Well found Sir!! smile
+1
Well done that man! wine woohoo
I will wait for any more praise until I can't see it myself on my car....is it easy to get the bleed pipe on?
Keith
Hello Keith ... yes, the extended clutch bleed screw is right there when you take off the rubber blanking plug. Bleed pipe fits straight on without any gymnastics!
Good boy!
Keith
