6 members (Arwyn Williams, Grumpy2, John Winn, Alistair, chanteclair, RichardV6), 301 guests, and 60 robots.
+8Rich 95
Posts837,266
#142736 02/07/13 08:54 AM
HJP Offline OP
I'd noticed some wear on the rear pulley from quite a low mileage, but it recently seems to have increased. At the 4000 mile service a couple of weeks ago Krazy Horse thought it was more than expected .
Having now done another 500 miles there's not a lot left on the teeth, a new one is hopefully going to be fitted on Friday.
Has anyone else found the same ?
My 'car' was a mid Sept 2012 delivery ,I understand the newer ones have a different shaped pulley with a lip to stop the belt moving from side to side.
Hugh
le Asbo du Bling
le Asbo du Bling
Are you talking about the sprocket on the wheel?
Mine seems okay with similar mileage but I was reading on a HD thread about sprocket wear and it seemed to be an issue when driving in dust environments as the belt picked up the dust and eroded the surface.
Slowly going green
HJP Offline OP
Yes , it is the one on the wheel, I did use it quite a lot in the winter when the roads were filthy ,but not in any particularly dusty conditions.
Its curious that yours is fine with a similar mileage .
Hugh
My original rear drive was replaced last week at the Factory - and its the "new" style described by HPJ. It looks v different to the original - and a New Belt which is also v different. innocent
My car has now done 4600 miles - May 2012
The new belt started squealing like a banshee after abt 50 miles - but sprayed Silicone Lube on it and it disappeared like a good un!so hope this is now fixed! laugh2
Neil
HJP Offline OP
That's interesting as it's a very similar mileage , were you charged for the belt and pulley or was it done under warranty ? As they've changed the design I'd like to think it's covered , especially bearing in mind the mileage.
Hugh
any chance we can get some pics of the new best and pulley. mine's a feb/march 2013 build and i'm curious to see how it compares to mine as i've had belt alignment issues
blake
sfmorgan.tumblr.com
Guys I am no longer a bike expert my last 2 were cardan drive for exactly this reason.
I wouldn't expect a long life from such a system coupled to a huge engine and a poor cush drive. Maybe HD forums could comment.
I think I remeber bike chains lasting around the 10 -15 k mark with low power bikes like CB360 or Triumph T140Vs
HJP Offline OP
I think modern o ring chains on bikes are pretty long lasting, although like you its a while since i had one .
Talking to people with Harleys I get the impression that the belts and pulleys are tough.
On my threewheeler the belt and front pulley look fine ,its just the rear one that's worn out , maybe the newer ones are a different material ?
Hugh
