3 members (Cerberas, Stephen888, Ian Wegg), 238 guests, and 89 robots.
+8Rich 86
Sagging Hood
Topics49,853
Posts837,447
Page 7 of 20 1 2 5 6 7 8 9 19 20
Originally Posted By Jays
How does it cope with without first rinsing off the stuck on dirt? I'd have thought thatbtherevwas a risk of scratching the paintwork.
It does say on the bottles that you need to clean heavy deposits of dirt off first!
I recently bought some and it's very good. I have a dark blue Range Rover and waxing it is a lot of work, so I cleaned and dried it first and then used this stuff. It was the easiest wax I've ever used. Wipe it on, wipe it off. Which when you have panels the size of barn doors is a bonus!
When I eventually get my Morgan, I will probably use my vast stocks of Zymol.... smile
+8 4.8
So after buying my Roadster in September and using it most weekends, I have decided that this weekend the car should have some TLC.
As it is black I will probably need to work a bit harder to get the shine back and all teh dirt off.
Has anyone tried Turtle Wax Black Box Polish and wax on their black cars? understand it can be a bit messy, but want to know if it is any good.
Thanks for any advise of otehr products to maintain high shine on a black car.
I am no purest when it comes to cleaning but I have a black car and use the turtle wax black polish and it's great. Will stain your cloths black but worth it and easy to use.
I would look at a paint sealant 1st like Auto finesse tough coat. Amazing product for shine and protection. If you want to mask paint defects then the turtle wax will work but its only supposed to be used in small areas. Finish the car off with a real carnuba wax. We offer car detailing so i have tried many different products over the years.
Good luck
henry
Thanks for the tip Henry....i'd not seen the Auto Finesse range before. They seem to have some interesting products and might well pull me away from my usual Meguiars products!
In the Morgan handbook it says use wax and not polish. I queried this with Morgans and they confirmed that polishes contain a fine cutting agent which removes paint from the finer edges on the Morgan. This is borne out by my friends +8, which had to go back to the factory because the paint had worn down to the primer on the louvre edges on the bonnet.
The paint is thin on the edge and you inevitably put more pressure on these fine areas.
I do however, polish the main areas avoiding edges, then wax
the whole car. When the wax goes the polish takes over until I can be bothered to wax again.
I use Autoglym wax that seemed very expensive at the time, but I have used it a lot and the pot is still nearly full.
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
Posting Desperado
Posting Desperado
Thats the stuff I am about to use it on the chassis and under the wings, but forget the tiny swirls movement go with the flow of the metal wing's from front to rear same on the bonnet etc it take longer but well worth it . It's about £45/- posted to my door but if it lasts a year then thats less than a quid a week . Wash your micro fibre dusters out and the sponge's ( keep them damp in a sealed food bag ) You can pick up a RAMER SPONGE in Boots these are the same except they are a little thicker 3CM so take that bit extra work load . thumbs
I use Autoglym wax that seemed very expensive at the time, but I have used it a lot and the pot is still nearly full. [/quote]
Thanks for the tip Jack. My sponges are greasy from the bonnet catches (see Quiet bonnet catches)and even with washing you pick up oil from around the car.
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
I have given up on polish as well and now use only wax. It gives a far deeper shine to my Sport Black car. I use Autoglym Polish only on the chrome bits as it still gives the best shine to chrome and metal.
David
2020 Roadster 3.7 Dove Grey.
A product called "Poorboys Natty’s Blue Paste Wax" which smells of chewing gum gets my vote no matter what it is used for.
Thanks for your advice Used2clean1 I have ordered a pot.
I'll keep you informed of progress.
2015 Plus 4 (GDI) Sport Green
