4 members (RichardV6, yrr13, Alan Patterson, Chris Cosher), 278 guests, and 29 robots.
+8Rich 95
John V6 49
Posts837,992
rockabilly john
Folks,
One of my LM62 Register owners in Italy is having the following error codes from his management system after the light stays on..
"The car is running well but the engine warning light is still on.
The error codes it gives are P200 and P272.
P200 is: Injector circuit malfunction
P272 is: Cylinder 4 contribution/balance fault"
I believe it maybe a Lambda Sensor but any other suggestions? He is heading from Florence to Sicily on his annual pilgrimage shortly!!! drive
Keith
Hi Minikeefy, the fault codes give you the first part of the diagnosis, P codes are standardised accross all EOBD platforms, * it looks like you have a fault on cylinder 4 which may be an injector related issue eg, supply voltage, short to earth, open circuit for instance.
It would be worth checking the basics first, Spark plugs, HT leads, compressions etc.
At this point I see no reason to see why there is a lambda sensor fault, yes, it may be reading excess oxygen due to the likely hood of a misfire as detected by the fault code P272, Cylinder 4 contribution.
hope this may help
regards Dave
Ta.. cheers
To close the thread....
It was the Lambda sensor drive
Now his accelarator cable failed in Sicilly!! (BHM sorted him out though!!)
Keith
Complicated things these modern engines! Reminder to Graham.... BUY A READER!
Yes, thanks J. smile
Pre-OBDII, so I have to find one that's compatible with a '93...
Given the actual fault codes, what made you conclude it was the sensor?
Nigel
Only that mine went a while back with a similar code.
Keith
