Topics49,871
Posts837,680
Posts: 27,817 Likes: 749
Posts: 27,817 Likes: 749 |
Thought it was cheap but glad you are up & running
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
1972 4/4 2 Seater
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Hi Today I have tested my car with good result. It run like it should and it started when I started it warm again. Iīll also have to correct a fault that I saw about the cost of the sensor. Itīs not 1.3GBP it was 13GBP. I have to blame my fat fingers. They do not always match those small smartphone screens.
//Fredrik Still a bargin to get you back on the road
Richard 1976 4/4 4 Seater
Posts: 28,904 Likes: 352
Posts: 28,904 Likes: 352 |
Hehe, My fingers NEVER match the 'keyboard' on a smart phone!!
Posts: 859 Likes: 1
Posts: 859 Likes: 1 |
Great news, happy motoring.
Neil
Honda S2000 Lexus UX 250h Toyota Auris Hybrid
Posts: 20 |
Hmm. I did a long trip today, so the engine was properly warm. Another fault appeared. Now I can start the engine after its warm but there is no idle. The engine ignites but it dies right after.
Any ideas?
//Fredrik
Plus 8 BRG RHD 1996 Husqarna Novolette 1955
Posts: 4,896 |
//Fredrik Please you up an runnign again, good result.
Adrian
Posts: 859 Likes: 1
I would check all the connectors to the sensor you changed. Seemed strange that this should happen after the previous problem.
Neil
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
On old fashioned cars with coils, when the engine started but then died, it was usually that the starting 12v feed was Ok, but the ballasted running 7-8v feed was broken. I don't know if this practice continued with electronic systems, but it points to the feed being there when cranking but not with the key in the running position.
Posts: 4,896 |
//Fredrik Please you up an runnign again, good result. Sorry to hear you still have problems, do you have a friendly garage nearby with computer that has Land Rover diagnostics. If so this may be the quicker and easier way to get to the source of the problem. They will be able to get all the error codes up and see what is failing. PS ECUmate is a diagnostic that you can buy that will do this, I know the chap that Designed/builds them (a TVR chap) and knowing him it will be good. ECUmate
Adrian
