3 members (RichardV6, Hamwich, TeddyAds), 280 guests, and 42 robots.
+8Rich 92
Posts837,278
Page 2 of 17 1 2 3 4 16 17
Lecat Offline OP
Thanks Gerry, I'll try to keep it up - the spell check works well I think wink
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
Welcome Lecat.
The rising rate front spring kits are almost ready and I have ordered a set. I have had a whole saga relating to ride height on a 2012 Plus 4 and have already had the springs changed under warranty. The ride height problem has been resolved but I am not entirely happy with the, now, rather firm ride. I have decided to fit aftermarket improved suspension to resolve both problems.
Send me a PM with your email address and I will send you all the information I have.
Lecat Offline OP
shiremog:
I will listen for the squeak - what kind of grease and what method do you use when greasing your bushings?
Hi & welcome. GoMog has lots on front end suspension.
Hello Lecat. Wishing you many happy miles in you Morgan.
Dave
Hook #118681 08/01/13 02:52 PM
Lecat Offline OP
Thank you all again - I will surely enjoy myself both here and on the road!
Originally Posted By Lecat
shiremog:
I used moly grease. My Roadster didn't have the oiler, just a single grease nipple on each side. The current Roadster has 2 nipples on each side, one at the top of the king pin & one on the hub, so more work to service this one innocent
I've also fitted gaiters over the springs to keep some of the weather off the king pins.
Ian
3.7 Roadster
4" Ruston Procter SD Tractor
1905 Merryweather steam fire engine
I use castrol cl grease as it is designed to be water resistant & for older style suspension systems.
+1- until I sold it, no KP's on the Lotus smile
3.7 Roadster
