6 members (JMcL, JohnHarris, +8Rich, Alan Patterson, John Wilcox, gomog), 221 guests, and 35 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,046
n1ck Offline OP
I have swapped the steering wheel on my +4SS to one of the Aero racing black suede ones. However I cannot seem to get the central horn push to work (though tbh I cant't recall if the old one worked either blush)
Any obvious areas to check?
Regards, Nick
Put the old wheel back on and test the horn - that will give you a better idea of whether there is a fault in the horn push area, or whether you should be looking further afield. Modern (OE i.e. cheap) horns don't seem to last too long... smile
To save taking the wheel off remove the push, disconnect the wire from the push and touch it to earth with the ignition switched on. If the horn sounds, it's a fault with the push. If not, the fault is probably with the horn.
Don.
n1ck Offline OP
Thanks for the advice guys . Looks like a problem with the push. smile
Regards, Nick
