Topics49,912
Posts838,160
Posts: 41 |
I have swapped the steering wheel on my +4SS to one of the Aero racing black suede ones. However I cannot seem to get the central horn push to work (though tbh I cant't recall if the old one worked either  ) Any obvious areas to check? Regards, Nick
Posts: 28,912 Likes: 354
Posts: 28,912 Likes: 354 |
Put the old wheel back on and test the horn - that will give you a better idea of whether there is a fault in the horn push area, or whether you should be looking further afield. Modern (OE i.e. cheap) horns don't seem to last too long...
Posts: 1,245 Likes: 2
Posts: 1,245 Likes: 2 |
To save taking the wheel off remove the push, disconnect the wire from the push and touch it to earth with the ignition switched on. If the horn sounds, it's a fault with the push. If not, the fault is probably with the horn. Don.
Posts: 41 |
Thanks for the advice guys . Looks like a problem with the push.  Regards, Nick
